i have got a sbd nylon pressure relief vavle kit now do i fit or not opinions please guys
20xe nylon pressure relief vavle
Re: 20xe nylon pressure relief vavle
Well, do you have oil pressure problems?
Personally, I put the nylon pressure relief valves in the same category as the 'breather mod' and cool running thermostats. i.e I've not had problems to need to mess about in those areas.
Exactly my thoughts above, all these mods are a cure for symptoms, not the disease.
Breather mod, just ensure to have proper crank ventilatilation as described on here a couple of times, with repeatedly positive results reported.
Cool running thermostats, if the car runs hot there is a problem and such a stat will only result in a larger delay time getting too hot.
Nylon valve, well just fit a proper pump, with the oval pickup pipe and you will never need one.
