What is the difference between early and late crank as far as fitting.
The seal on the oil pump?
Is the cambelt pulley swappable?
Is the flywheel bolt number the same early to late... I do remember the 8v 2L had less bolts.
The main different is the overall weight and the round and square tooth belts... that's about as much as I remember.
What is the thoughts on using 20.3 or 19.3 wide bearings when using H beam rods. Wider is better giving more bearing area?
