C20XE Water Pump
  • C20XE Water Pump
    Anyone know if the 2.0l 8v water pump fits the same as a 16V one? They certainly look very similar.
    Other than the price difference... there just seems to be more stock of the 8V ones here for some reason.
    Re: C20XE Water Pump
    Afaik they are different... There are very good aftermarket ones from EBC with metal impellor as well.
    Love your work and mods on the car mate!!
      Thanks... yeah really what a bugger... hmmm wonder where they are different?
        Well I have a 8v block (20seh) and ecotec head (x20xev) ect with a eco pump, the diffference is in the drive pulley eg width for the belt and tooth shape.
        So far I have found the Valeo and QH have plastic impellors (never used to) but a 'cheap' firstline brand one has metal, I dont know what brands you'd have over there though.
          Cam belt teeth profile?
          First Line are cheap, for a reason. Not quite the same but my Mk4 got through a water pump in about 30k miles (no leaks but enough play for me to replace it). Also their drop links only seem to last about 10k, on my second set now.
          They're good to get you on the road, or for an emergency, but I wouldn't use their stuff on a big money project.
            Got a spare brandnew EBC here on the shelf, though won't sell for cheap since they are not in production any more... Would want at least €50 for it, which is probably over 100 aus. dollars.... and then the horrible shipping price halfway over the globe. You'd be better off getting one from a shop I guess...
            Did see some 1.7 diesels and 1.8 engines also use the same pump...
            The full compatibility list:
            MAKE MODEL cc Valves CODE YEAR
            VAUXHALL ASTRA 1.7D 8 17D 1989-1993
            VAUXHALL ASTRA 1.7D 8 17TD 1994-2000
            VAUXHALL ASTRA 1.7D 8 17DR 1992-8/94
            VAUXHALL ASTRA 1.7D 8 X17DTL 9/94-1/98
            VAUXHALL ASTRA 1800 16 C18XEL 1994->
            VAUXHALL ASTRA 1800 16 C18XE 1994->
            VAUXHALL ASTRA 2000 16 X20XEV 1994-1998
            VAUXHALL ASTRA 2000 16 Z20LET 2002-2005
            VAUXHALL ASTRA 2000 16 Z20LEL 2004->
            VAUXHALL ASTRA 2000 16 Z20LER 2004->
            VAUXHALL CALIBRA 2000 16 X20XEV 1992-1998
            VAUXHALL CALIBRA 2000 16 C20XE 1990-1992
            VAUXHALL CALIBRA 2000 16 C20LET 1992-1998
            VAUXHALL CAVALIER 1.7D 8 17DR 1/92-8/95
            VAUXHALL CAVALIER 1.7D 8 17D 1/92-8/95
            VAUXHALL CAVALIER 2000 16 20XE 9/92-1995
            VAUXHALL CAVALIER 2000 16 X20XEV 9/92-1995
            VAUXHALL CAVALIER 2000 16 C20XE 9/92-1995
            VAUXHALL CAVALIER 2000 16 C20LET 1992-6/94
            VAUXHALL FRONTERA 2200 16 X22XE 1995-8/98
            VAUXHALL FRONTERA 2200 16 X22SE 9/98-1/04
            VAUXHALL OMEGA 2000 16 X20XEV 1994-7/99
            VAUXHALL OMEGA 2200 16 Y22XE 8/00-8/03
            VAUXHALL OMEGA 2200 16 X22XE 6/99-7/03
            VAUXHALL OMEGA 2200 16 Z22XE 8/00-8/03
            VAUXHALL SINTRA MPV 2200 16 X22XE 1996-1999
            VAUXHALL VECTRA 2200 16 X18XE 1996-1998
            VAUXHALL VECTRA 2200 16 X18XE1 1988-2002
            VAUXHALL VECTRA 2000 16 X20XEV 1996-2002
            VAUXHALL VX220 2000 16 Z20LET 2002-2006
            VAUXHALL ZAFIRA 2000 16 X20XEV 5/99->
            VAUXHALL ZAFIRA 2000 16 Z20LER 2005->
            VAUXHALL ZAFIRA 2000 16 Z20LEH 2005->
              Had a look at Some water pumps and despite they saying they where for a C20XE they certainly where either really a C20NE or just shit machining.
              First indicator was the adjustment tag which was hooked over like a 8v one, then there was the backing plate which was definitely 8v one. I took a chance and took one home and bugger the pulley despite being the wider of the 2 they had... it was too tight on the cam belt still and the last straw it was 1mm undersize in the body so it felt sloppy in the block... this could have been just bad machining.
              So I went to GM Holden and they had one in stock... he fetched it for me and it had a plastic impeller... ahhhhhhh!
              So I gave up and cleaned the old one... fitted a new O ring and put it in the engine.
