Hi,did the c20let have a coscast head???????????
coscast head(c20let)
Re: coscast head(c20let)
are the heads for the let and xe interchangeable? i have an let about to rebuilt for my champ with a gm head on it, can i replace it with my coscast that came from an f plate gte xe. i appreciate the valves might be different but are the heads themselves the same???
ahhh so the valves and guides are the same too? that makes life a bit easier!!! so keep the let exhaust cam in and fit an xe inlet cam? i've heard this a lot, why just the inlet cam????Originally posted by Mr-G View PostSame head mate just different cams
, when you rebuild the LET head use the inlet cam from the XE head though as it has more lift
Exhaust cam is specifically designed for turbo applications but the inlet cam is a little lazy, the XE inlet cam has a higher lift an iirc a longer duration so increases tourque.
iirc the later heads had different valve guides and shallower valve seats but other then that they are the pretty much the same. The earlier Coscast heads benefited from hand finished ports whereas the later GM heads were just straight from the cast.Last edited by Mr-G; 11-01-2009, 12:40 AM.
both the inlet and exhaust are specifically designed for turbo on the c20letOriginally posted by Mr-G View PostExhaust cam is specifically designed for turbo applications but the inlet cam is a little lazy, the XE inlet cam has a higher lift an iirc a longer duration so increases tourque.
just like the inlet an exhaust are specifically designed for n/a on the 20xe
the reason a xe inlet is only used is because of the dizzy and hall sensor, if you change for a inlet and exhuast you would need to change the timing of both cams to get rid of some valve overlap something that n/a engines use to ''suck'' in the new charge of air and fuel, however on a turbo engine you can blow the new charge out of the exhuast so we need to get rid of some of the overlap.
now the problem with adjusting both cams is the dizzy on the turbo engine, if you spin around the cam into a different possition you also change the possision of the rotor arm inside the dizzy this changes the ignition timing either retarding it and loosing you power and gaining heat, or advancing it and maybe causing det and a dead engine.
most of us on aftermarkt managment change both
So if using standard management with both XE inlet and exhaust fitted would you see more gains than if just the XE inlet was fitted?
Thats if the dizzy was adjusted so that it sits in same plase as it would in standard form ie moved round so the rotor is where it should be (i realise its not as easy as just turning it)
