F28 onto a C20XE what will need changing?
  • F28 onto a C20XE what will need changing?
    I know I'm going to need to change the clutch, but not sure if it will bolt straight up to the gearbox mounts. Anyone know or have a guide to fitting the F28 into a Mk2 2?
    Cheers
    Isaac
    Re: F28 onto a C20XE what will need changing?
    The XE will struggel with the F28 in 6th so its pretty pointless
      The throttle bodies, Mbe management and N2O should help there.
        i'll have a look through my pics in the morning. there's a few bits need grinding and re-welding for the rear bracket as there's 2 bits where the 16v bracket fouls the casing. the front you just use the F28 gearbox mount with your 16v engine mount
          ignore the extra bits welded on, they were extra bracing because my casing was goosed. you need to grind off the lip and seem weld it back up...you'll see what you need to trim off when you put the mount next to the box. the plate where the driveshaft goes in is just a normal F20 one, you'll need to drill & tap the casing for the bolts. mines got a spigot ring inside too
          as for the speedo ring that's a job i've not done on my current box (didn't have the time and wasn't keen on splitting the gearbox if i'm honest) at the moment i've got my clocks set to KM's, up to 50 mph it's the same as my road angel upwards of that and it over reads (70 + 75 real speed etc)
          hope this helps...best I can do at 1 in the morning
            you will also need the flywheel, clutch and release bearing for the f28, the only part i had probs with was setting up the gear selector it took about 1 hr to get it where i was happy with it
              use the f20 flywheel and 1/2 the clutch from each
                Cheers Baz. That's a great help.
                  disagree really, thats how mine runs at the moment and doesn't struggle at all over 45 mph. 6th gear probably should have been there from new IMHO.
                  I've heard 6th in the F28 is the same ratio as 5th in wide ratio boxes.
                    wide ratio boxes have much bigger final drive than F28 though, less road speed more turning force like for like.
                    i tend to agree, i wouldnt put a 6 speed on an XE on purpose, just for the 6th. increased engine load trying to propel the car in 6th probably negates the fuel saving that youd expect from keeping revs down. significant weight difference in the box too, and significant increase in transmission losses also
                    i know someone who has gone back to a F20 because of it, but when alls said and done i wouldnt take it off it was already there on a car i bought.
                    you could use an flat flywheel, 20XE clutch cover and F28 drive plate like astrayorkie said. one would assume the clamping load was uprated on the proper turbo clutch cover though.
