Ecu 2.0 8v
  • Ecu 2.0 8v
    I've done a little research but thought I'd ask, as far as I can read my 8v gte has two rows of on its ECU , and quite a few of the SEH ECUs have 3 rows as the are from the later mk3 cavalier, but does anyone know which numbers are for the 2 row SEH ECUs
    If all I've written is way of the mark could some one put me right please thankyou
    Re: Ecu 2.0 8v
    2 row motronic ML4.1, ident FH, bosch 0 261 200 116 20SER engine
    3 row motronic M1.5, ident GD, bosch 0 261 200 374 20SER engine
    3 row motronic M1.5, ident GC, bosch 0 261 200 372 C20NE engine (only fitted to cabriolet in the UK)
    3 row fitted 1990 onwards iirc
      Re: Ecu 2.0 8v
      My ecu number ends 115 with FH ident so I'm going to guess that I can't put a SEH ecu on my car, does that tally?
        Re: Ecu 2.0 8v
        as you rightly pointed out there are slight variations of last 3 digits of the bosch part number (usually for different vehicles) but its not the case that SEH ecus are 3 row, you can get both 2 and 3, just like astra 20SER ecus.
        if you can find a 2 row SEH ecu it will work fine, but it wont be the same ident as astra version. for example the 3 row SEH ecu for cavalier is GF, 3 row C20NE ecu is GE
          Re: Ecu 2.0 8v
          bit of googling, 2 row cavalier ecu is FU ident, bosch part number ending 133 and 134
            Re: Ecu 2.0 8v
            Thankyou Darren for looking into it for me, that's good news, it's much appreciated, now the search begins
              Re: Ecu 2.0 8v
              cool i've got a "box of random" 2.0 8valve here, will check to see if there is a 2 row ecu
                Re: Ecu 2.0 8v
                edit, thats a negative. have 3 row GD
                  Re: Ecu 2.0 8v
                  ill have a look i have a few of them as went turbo on my 8v
                    Re: Ecu 2.0 8v
                    Thanks for looking Darren, cheers Neil that would be cool
                      Re: Ecu 2.0 8v
                      You can always just swap the loom for a 3 row type only takes a few minutes, the only other thing you need to change is the throttle pot rest of it can stay the same and it plugs in with no hassle.
                        Re: Ecu 2.0 8v
                        Oooo didn't think of that, that's an idea, will any astra 3 row loom work?
                          Re: Ecu 2.0 8v
                          If it's off a 2.0 8v and has the flap type air mass meter I don't see why it wont, I would suspect a cav loom would also fit ok.
                            Re: Ecu 2.0 8v
                            cheapest one could find on the bay
                              Re: Ecu 2.0 8v
                              That's exactly the same as what's on car , checked it earlier when I got 5mins , so that's a SER ecu correct?
