Door hinge Pins, Best way to remove them?
  • Door hinge Pins, Best way to remove them?
    hi, just woundering as ive got a door on my belmont that i need to change.
    what the best way to remove the Door pins?
    or it there like a speciel Tool need to remove without damage?
    thanks
    Re: Door hinge Pins, Best way to remove them?
    Dead easy with the right tool...
    Slide the right pin in and tap / hit / smack the bar with a hammer to slide the door pin out.
    So Long, and Thanks for All the Fish
      Tap the bottom of the hinge pin upwards gently so as not to spread it, then when there is enough of the top showing get a pair of small mole grips or pliers under the neck and keep tapping the underside until the pin comes free.
        nice one cheers guys
        will invest in one of those tools, 1 thing that i dont have
        thanks
          You can have the Km(opel tools) tool that will do great work.....or same like that...
            new pins from vaux aint to mush to replace if ya naff your old one , ive just bought two as ive just replaced the drivers door less than £2 for the pair .
