Looking at Gterie’s thread I noticed he used the vxr injectors so I have order 4 today which will be with me next week. Hopefully this will sort the issue. I have also ordered a fuel pump just in case and a fuel filter.
GTE Turbo
Originally posted by G.TERI.E View PostJust looked at the pictures, looks like she has kept well in storage all them years just the dust and grime hiding a nice bourduex red paintwork, love the wheels
Sounds like a good plan,.. 20yrs is a long time for any car to be stood bound to have cracked or perished tyres, perished bush's, CV joints, corroded disc's etc.
personally I would get it washed then engine running, stick it on a ramp have a good look what needs replacing.....
Anything you want to know just ask.Last edited by G.TERI.E; 02-05-2020, 09:17 AM.
Got one working ish, it was more of a jet than mist, this one above wasn’t working at all and didn’t bother checking the other two. D6FD6FC1-5DB1-426E-AF05-8EC26E007B29.jpeg
just waiting for the new ones to arrive now.
Meanwhile I got the seats out yesterday to give them a needed clean. The interior is still in very good condition.
The leather on the seats were very hard. I gave them plenty of conditioner. After a couple of hours they really started to soften up nicely. I may even go over them again today. I think they turned out well although somehow I lost the bracket lower bracket that holds them in place. Hoping it’s at the workshop. 10F85BD7-0F3C-4318-9B28-657986EB900E.jpeg1D57B775-AEF1-42C6-BCF5-D66485CB626C.jpeg618F20C1-67E0-4D06-ACB1-0A616B13DB20.jpeg5F191623-24EB-48D3-8791-945DB538CB00.jpeg
- Likes 2
The injectors came today, they’re in now and the good news is she’s now a runner. The engine is running fast. From cold it’s about 1400 rpm but only drops to around 1200 rpm when warm so a bit more investigative work needed. We know there is a bad earth. We know there is a leak from where the nitrous is fitted to the intercooler pipe. We are going to remove the nitrous and cut and sleeve the pipe for now, I will be ordering new pipe work further down the line once it’s running correctly. I have new fuel pump on the way and fuel filter. The timing was at 17.9
Check the ICV idle control valve (under the intake manifold as they are prone to sticking but doesn't sound like it as yours is idling somewhere near where it should be. Well worth removing it and giving it a really good clean with brake cleaner then add a small amount of WD40 to keep it oiled before refitting. Also check all intake and vacuum pipework for any leaks, also check vacuum pipework for blockages. Clean the throttle body and double check the timing belt is spot on. Looks like you have a solid base to begin with but check the sills, drivers steering rack mount and have a jolly good poke about to ensure Mr Rusty and Miss Rot haven't been lurking since it was mothballed all those years ago. Good luck with it
