Specs
  • Specs
    Does anyone know what the original quoted specs for BHP, MPG, top speed, 0-60 for the mk2 1.2, 1.3, 1.4, 1.6, 1.8i, 2i were?
    For the hatch.
    Re: Specs
    thats all bar the 0-60
      Re: Specs
      Just a FYI, I drove my LET onto the weighbridge at work today, weight as measured, with a blinking fuel gauge was 1120KG
        Re: Specs
        from the 1991 model brochure, edition one:
        3 door kerb weights:
        1.2 merit 855kg
        1.4i merit 865kg
        1.4 merit 855kg
        1.6 merit auto 920kg
        1.7d merit 920kg
        1.4 l/lx 882kg
        1.6 sx 916kg
        1.8 sxi 960kg
        2.0 gte 997kg
        2.0 16v 1042kg
        5 door models add 20kg except
        1.4 gl 902kg
        1.6 gl 932kg
        1.8i cd 1016kg
        Power:
        1196cc 55ps
        1.4i cat 60ps
        1.4 75ps
        1.6 82ps
        1.7d 57ps
        1.8i 112ps
        2.0i 124ps
        2.0i 16v 150ps
        top speed: 0-60 mpg at 56mph
        1.2 4sp 96 17.0 55.4
        1.4i 4sp 99 15.0 51.4
        1.4i 5sp 99 15.0 55.4
        1.4 4sp 106 13.5 54.3
        1.4 5sp 106 13.0 56.5
        1.6 5sp 109 12.0 57.6
        1.6 sx 111 12.0 55.4
        1.7d 95 18.0 70.6!!!
        1.8i 121 9.3 55.4
        1.8i sxi 123 9.3 50.4
        2.0i 127 8.7 49.6
        2.0i 16v 135 8.0 51.4! yeah right!
          Re: Specs
          i thought 0-60 for gte 16v is 7.3 secs?
            Re: Specs
            I thought it may be lower, but thats whats in the brochure!!! I know for a fact a sxi estate does much more than 117mph as standard.....
              Re: Specs
              my gte 16v brochure says 7.4
                Re: Specs
                Is that with full interior and F28 ?
                  Re: Specs
                  i went onto a weigh bridge with my gte too. when i knew for a fact its kerbweight was 1037 from the factory, and that i had removed 400kg. the weighbridge said it weighed a metric tonne, on the nose.
                  not saying they are crap, just saying they spend all day weighing in and out 30 tonne dust carts, is it safe to assume its accurate in the lower echelons ?
                    Re: Specs
                    Yep, full interior, LET, frontera IC, and F28...and yes they are mega accurate, as they weigh tankers coming in to the factory, and weigh them after the delivery, and we get charged on the difference, so the scales are calibrated every month, iirc.
                      Re: Specs
                      Thats interesting because I know that F28 is 20kgs more than the F20.
                        Re: Specs
                        that was my point, they come in 20 tonnes and go out 40 or whatever. so why would they be accurate measuring only 900 kilos or whatever?
                          Re: Specs
                          mmmmmmm, i see your point. I'll ask the guys at the weighbridge and see if i can have a peek at the calibration data... the real test is to weigh myself and go and stand on it!
                            Re: Specs
                            i see where oddball is coming from too! need go car place really!
                              Re: Specs
                              yeah our local quarry doesn't seen to be correct, the g/f's clio is ment to be 935kg's and it was over 1000. this might be stating the obvious but when you are weighing you cars you get out and stand off of the weigh bridge?
