Brake Caliper - ATE or Pattern?
  • Brake Caliper - ATE or Pattern?
    Really annoyingly, I was in the process of refurbing an old rear caliper with new piston, seal, etc when I snapped the nipple off. Tried drilling and eazi-out with heat, no way, it must be welded in there so basically, the caliper is scrap.
    VX no longer do any rear caliper or component (caliper, pads, mounting kit, nipple. NOTHING).
    I can get a refurbed ATE caliper for about ?95, or a pattern caliper for ?63.
    Opinions on ATE vs Pattern please!
    http://www.ebay.co.uk/itm/BRAKE-CALI...cAAOSwB3BZ~LV3
    Hi, I think i have a couple of used calipers in my lock up, if intrested i can have a look in the week for you?
      Ooooh, yes please!
      Sorry for the late reply, not logged in for a while.
      I have a cunning plan to fix it though.
      I managed to get the bottom of it out (the bit with the taper, so that bit is fine), but most of the thread is gone.
      I was going to try the highly risky helicoil fix (must be drilled and tapped perfect or it wont seal on the taper), but just came up with a brainstorm idea.
      You can buy banjo's with a nipple built in to them.
      I'm thinking, get the banjo hole welded up, drill and tap the caliper nipple hole out to suit the banjo, screw the banjo in to the new hole and maybe get it brazed in to make it 10000% sealtite. I will then have a new seat and perfect thread and nipple.
      Thinking about using this...
      https://www.ebay.co.uk/itm/Stainless...EAAOSwQS1aBFVj
      Opinions?
        On that point I've just seen this .. a bit pricey but an alternative ....
        http://www.fraserbrowneng.co.uk/stor...&product_id=51
        L
          Thanks, I saw the nipple therapy kit, but a lot of money to fix one nipple.
            Originally posted by Jags C20LET View Post
            Ooooh, yes please!
            Opinions?
            Hi mate, i found one but it needs a good clean its full of rust but the nipple is ok, if its anygood to you ill post a photo tomorrow night
              Thanks bud, it's the passenger side I need. Pics would be great, the bit that needs to be good is the sliding surfaces the pads sit on
                No problem i will do that tomorrow evening for you as im out sea fishing tomorrow so wont be back til later
                  Hi mate. No worries, I found one! NSR reconned and delivered from Latvia for ?48. I also managed to get a recon OSR for ?18. ?66 the pair. Result. Thanks for the offer.
                    Ok mate no probs, sorry for the delay in posting up the photo just been really busy
                      It's ok buddy, no biggy
