Astra ABS master cylinder - two port or four?
  • Astra ABS master cylinder - two port or four?
    The previous owner of the car removed the ABS module etc 'to save weight'.
    I've put everything back in, the ABS module has two inputs from the M/C but my original M/C has four?
    Was there a two outlet master cylinder at all? I've spent a few months getting all this back together again, it's been painful.
    mine is ABS and has 2 ports
      as above. normal master cylinder has 4 outlets, abs master has 2 (then splits to 4 circuits at the pump)
