Xe Distubtor part numbers
  • Xe Distubtor part numbers
    Hi
    I have 2 identical looking Distubtors that the caps and arms fit the same but both have different part numbers, my engine is the early 20xe and I'm trying to find out what one is correct for my engine
    Part numbers
    0237521015
    0237521026
    0237521015 is for 20XE up to engine number 14180385 (GM part 90296504)
    0237521026 is for 20XE from engine number 14180386 onwards (GM part 90350593)
    0237521015 is for C20XE up to engine number 14028514 (GM part 90296504)
    0237521026 is for C20XE from engine number 14028515 onwards (GM part 90350593)
    dont ask me what the difference is because ive only just learned there are two different distributors ! but at least it answers your question
    the only coincidence i can find is that the "late version" is same part number as C20LET
      Thanks for that Darren, will check the engine number and fitt the right one, not sure this will cure the problem but at least the dizzy will be correct.
      ​​​​​​Just re gapped the plugs to 0.8mm hopefully that will help
        My engine number starts with 1400 so 0237521015 it is then, this isn't what was fitted.
