F28 gearbox
  • F28 gearbox
    hi all
    I am running an F28 in my 16v. The throw between gears is huge.
    Questions for you ....
    1.what linkage should be used? Looks like I have the std F20 fitted
    2. Should the shifter rod be modified I.e shortened ? Mine isn?t?
    3. What can I do to reduce the travel between gears ? Short shift possibly ? f28 linkage ?
    Cheers
    used to be laods off the peg (like m-tech), but the only one i can find these example links
    https://www.lmfvauxhall.co.uk/M-Tech...Shortener.html
    https://www.short-shifters.com/x-shi...ifter-kit.html
    the principle is the same on all of them, alter the distance between pivot on the arm on the gearbox mount. you could modify your standard one if you are confident.
