F16 clutch change
  • F16 clutch change
    hi
    anybody have some tips on changing the clutch on a mk2 astra sxi with f16 box?
    Looked in Haynes manual but not applicable to the f16 box with regard to the input shaft.
    if i remember it right haynes shows a big hex bolt that you undo which reveals the input shaft? later gearboxes are exactly the same but you have to take the whole end plate off.
      Hi Darren. Thanks for the reply. You are spot on. Looked in my cavalier Haynes manual and it mentioned taking the whole end cover off. Sorted now !
        My late F10 is like this as well, take the end plate off - don't forget the new gasket, and don't forget to reattach the engine earth strap as I (nearly) did...
        My current fleet!
        1989 Astra GTE 16V
        1985 Astra 1600SR
        1991 Astra Mk3 1.4LSi "The Shed"
        1984 Opel Monza 3.0 GSE
        1984 Porsche 944 Lux
        1986 Toyota MR2 Mk1a
