C20XE distributor torque spec
  • C20XE distributor torque spec
    Hi folks, greetings from lovely Czech Rep. I am still struggling a little with my C20XE distributor leaking a tiny bit of oil... I replaced the o ring, still leaked, then applied some RTV, leaks still. Not much but it does and it is dripping on my newly restored block/gearbox which is not acceptable (took a lot to clean it you know )...
    I believe I might have "overtightened" it.... anyone knows the exact Nm torque spec? I went through different DIY books for Kadetts/Astras but no luck....
    and just for fun, to make your Monday nicer, here is that jewel of mine
    Hi, sorry I have no idea at this moment how tight it should be (but so many people over tighten bolts without thinking the impact) you could try making a thick paper gasket also to see if that helped take up any distortion in the surface?
    However, are you sure that there is not a high back pressure forcing the O-ring to pass the oil? I assume you have confirmed that all engine breather airways are good and functioning correctly?
    P.S. The car looks great.
    2002 Omega Est, 1978 MGB GT, 1973 Honda CB500 K2, 1993 Honda Sevenfifty, 2013 Astra GTC 2.0 cdti .......
      Having also looked for a torque setting for you I very much don't think there is one if there was it would have probably been in this document.
      http://www.sbdev.co.uk/Info_sheets/T...20XE%2016V.pdf
      But I'm sure someone will have some ideas.
        is it leaking between where the distributor joins to the cylinder head, or leaking out of the distributor itself ?
        p.s did you replace the O ring on the pin that inserts into the middle of the camshaft
          The tiny o-ring Darren is referring to is #5 here. You might also want to look into replacing #4 o-ring as well as I believe you have already replaced #6.
          I've had a look through the C20XE torque settings I pulled from TIS and can't see anything specifically listed for the dizzy. However I did pickup on the following so I'd suggest you use this as a general guide as the two main dizzy to head bolts are M8.
          M8 - 20 to 22Nm
            Hi guys, many thanks for replies, it sure leaks through the o ring through the place where dizzy is mounted to the cylinder head..... I applied sealant and it got a little better but not much... I have noticed the old o ring had a sealant on it right away rather than on the surface where the dizzy goes to the cylinder head. I however believe I used much more than 22Nm as I kept tightening it couple of times trying to stop the leak... I will probably try to take it apart once more and use little more sealant and use some 20-22Nm... I have a torque wrench so should be no problem...
              Maybe you could source a slightly thicker "O"ring, some garages have kits that will make them up from a straight rubber length and super-glue the ends together (this is old school and how we (I) used to make them in the 70's )
              Or you could try a double wrap of PTFE plumbers tape below the O-ring ... As in slip the O-ring off from the grove, wrap a thin strip of PTFE tape and replace the O-ring on top still dropping into the grove. You may then need a lubricant to help it back into the head and be careful to ensure there is not a sharp edge to damage the o-ring as it slides in. And on that point be sure there is no crud on the surface where the o-ring sits in the head "it only takes a grain of crud or a deep scratch"
              Laurie
