Hello!I have a very bad experience with c20xe after overhaul and full rebuild grind of crankshaft new bearings 0.25 main and rod new cambelts new seals gaskets everywhere i got just 1 very bad problem with the oil pressure.The previous engine had worn bearings and the 3rd rod came out from the block so i decided to get new block with hone and new grind crank because the old block and crank had damaged and went to recycle.After the rebuild i put oil GM 10w40 but i saw that when the engine got hot the oil pressure gets to 1 bar measured with digi and manual pressure sender the pump is same like the previous engine where i didn't had such a problem the engine was 300k with OEM bearings so it's okay to be worn after 300k but the oil pressure was staying 3 bar on hot idle 5+ when revving.Now i adapted the engine 1000km then changed the oil with Total Quartz 9000 10w50 oil grade was thinking that the oil is the problem.After more 1000km driven with that oil 10w50 grade engine had worn all the rod bearings plus main bearings but mostly the rod bearings the 4th rod next to the oil pump was hardly damaged the bearing was just the metal body everything was down in the sump.Then i said okay i will put other pump to check if the pump fail i put new bearings put the pump started the engine and same shit i just ran it for 20 kilometers then went back to the garage dissasembly everything and saw that the bearings are worn alot for 20km driven.Mostly the 4th rod bearing is worn more than the other ones i got plasti gauge i measured around 0.035mm-0.050mm clearances which is in specification i measured 3 times on rods to be sure and looks everything is okay.I'm planning to put z20LET pump but its very expensive so my questions is is it worth to put this expensive pump and if it doesn't fix my problem then im screwed again.I'm asking because i measure everything then i got again low pressure the both pumps are old but this pump worked correctly on my previous engine which fail very bad,but didn't worn bearings so hard after 300k like now after 20 km driven.I tight Main bearings to 55nm rod bearings to 45nm correct me if i'm wrong.
Every advice is welcome i'm really confused what to do and i really appreciate your help thanks in advance.
