Horn wiring help
  • Horn wiring help
    All sorted
    All sorted
      All sorted
        pretty sure the gtes have 1 horn which is direct load through the horn push, and a fused relay piggy backed to that for the second of the dual tone. right old lash up
          Definitely is a lash up almost like they forgot to fit it and did a last minute Friday afternoon job
          I decided to delete this gm design and start again so fitted a new 4 pin relay/10A fuse with a negative trigger by the aftermarket horn push, it now works perfectly with the insignia twin horns
          Had to run a new wire to the pin behind the steering wheel because the old one had been cooked at some point!
          Do you know if that single brown on the pin behind the steering wheel is just a negative because the other end is by the original horn with a cone shaped boot on the end? If so, that can be deleted as well.
