[Brazil] Kadett SL/E C18NE
  • [Brazil] Kadett SL/E C18NE
    Hey guys,
    My name is Hygor, i live in São Paulo - SP
    i have a GM Kadett 1993, model SL/E - C18NE - EFI
    My future plans is GSI Style and C20XE or C22XE !
    Project Step 01
    * rotten trunk with several rust spots
    * Rear fender with light rust
    * "crack" to weld
    * water entering the trunk
    * small rust spots on the underside of the carpet
    * driver's door out of place
    * Bottom with dents and grated
    * Passenger Door with smashed light
    Project Step 02
    SECRET
    :05.18-Perturbado: i live in Brazil..... w8: Indiferença: .... $$: Confusão:
    Re: [Brazil] Kadett SL/E C18NE
    Welcome to the site, car looks nice and tidy
      Can't believe this thread has gained so little attention, it missed mine too at the time, that I can't believe already!
      Such a nice Kadett, and great to see the lot of them in that last picture!
      So, as far as I know you can build your 1800 engine to 2 liter, and with XE head and motormanagement you will basically have a C20XE.
        E ai, tranquilo?
        Seu motor assim como o meu é um C18NZ, atualmente ando com o 16v do astra, então C18SEL hahaha
        Muito bonito seu Kadett, parabéns!
        Aqui no sul temos bastante 16v...
          Greetings to my friends, after months I managed to accomplish some UPs in my car, and now I am returning to active.
          Thethat was already done:
          *Bye Bye C18NZ
          Now is : C20NE
          Piston 86mm for
          Alcohol and Flywheel relieved witch 3kgs
          *Fueltech Ft250 + 4 Injector
          *Rims 15" from astra mk4
          *Suspension KIT: Springs
          Eibach and Damper "DownWorks"
          So far this setting aims 160Hp !!
          What is still lacking:
          *Garret .70
          *Intercooler
          *600HP
          For now is basic, I am uploading photos and already update,, Thanks!
            Cool!!
            Just a point,
            Are you using the taxed piston? If so, I think you better change it before installing your turbo.
            Send some pictures!!
              Yeah, I will use less pressure however has more power
              With 0,6bar = 215Hp of course with a good hit and intercooler
              nowadays:
